Rip 3D Blu-ray to 3D MP4
05/27/2020
DVDFab Blu-ray Ripper can easily rip 3D Blu-ray to 3D MP4 to meet the display requirement of your 3D devices. Everything is professional and flexible. A few steps and mouse clicks, the task will be done. Just look at this following tutorial.
Step 1: Start up DVDFab 9, choose Ripper option and load in the source
Start up DVDFab 9 and choose Ripper option. Insert the BD you want to rip into optical drive, and the movie will be imported into DVDFab very soon. You can see the longest movie title is selected by default and the audio tracks and subtitles can be changed.
Step 2: Open Profile box to choose a profile
Open Profile box to go to 3D Format to choose mp4 on the left panel. Then go to choose a profile for the output.
Step 3: Customize your own 3D
Click Advanced Settings button to bring about all parameters of video, audio and 3D so that you can go to set them freely. For example, you can choose the 3D format as side-by-side 3D, top/bottom 3D, anaglyph 3D, etc.
Click Edit button on the main interface to open Video Effect window. You can choose Resize to go to set the source aspect ratio and frame resolution of the video; you can choose Crop to crop the image for display.
Step 4: Start conversion
Hit Start button to start conversion. During the process, you can view detailed progress info and preview the progress with real time images.
OK. Done. More info about DVDFab Blu-ray Ripper can be found at: https://www.dvdfab.cn/blu-ray-ripper.htm
